A Simple Plan!
Ozpulse replied the topic: Re: A Simple Plan!
At least you only have 20 weedy motors layin around! :blush:
#14106
isuzudude replied the topic: Re: A Simple Plan!
Sometimes that NOT a good thing...when you're limited on space!! :(
#14109
Aww!
Whats a bit of OCD between mates! :blush:
#14119
Well I got a little bit more done! ;)
At least its starting to resemble a boat anyway! :laugh:
Bottom is glued and just got the sides on, still need to trim and sand before a coat of resin inside!
As you can see there is plenty of room for a 30cc homelite without trimming any casing, I cut the centre bulhead out aswell to allow more room to get the balance right! B)
I also sloped the rear down to the transom to get rid of the boxy rear!
#14142
Woodie replied the topic: Re: A Simple Plan!
Hi Oz.
Looks good! Remember to remove resedues of glue. Should save a few grams of weight on the boat. I do that myself... :)
BTW: Watch out for that green animal under the bed! Don't trust it too much. I would'nt do that myself... :)
Will do Woodie! ;)
Once I clean the glue up etc. I will be using some fibreglass cloth tape to reinforce
all the inner seams.
Dont want it to start coming apart the first time it takes a tumble! :blink:
Will also get the top sheet printed out and cut today!
#14144
Moofy07 replied the topic: Re: A Simple Plan!
Hi Oz,
Coming along nicely. B)
Moofy
#14149
Looking good Bud!!!! Keep it coming!!! B)
#14150
Test fitting the top sheet before I finish sanding the frames etc. ;)
#14164
Hi Oz,
LOOOKIN' GOOOOOD. B) (Are we there yet?) :woohoo: :woohoo:
Moofy
#14165
