My Avenger
douga replied the topic: Re:My Avenger
great looking cat I,m new to sport & looking to build cat from scratch could you point me towards plans or dimensions of like racer?
expat kiwi in vic aust The challenge of building & then racing attracts & seeing some of the boats on this site sure is spectacular
great work; douga
#3621
marc replied the topic: Re:My Avenger
Nice running cat. Can tell that the motor has loads of power and the pond is too small!!! :)
#3623
QDRevenger replied the topic: Re:My Avenger
Marc, yep too small, just our little test pond, make sure things are working. I can get 68mph in that little pond, not on that prop though. I've not made the turn a few times, put it into the bank. Have water, must use:silly: .
Douga, Heya Kiwi. Not sure of any available plans for cats, plenty of mono's and hydro's. Someone else might know of some. My Avenger is 44\" long you could probably work out some rough dimensions from the pics.
QDRevenger.
#3631
First race day of the season, biggest storm in 10 years, 160km winds:( . Pulled the pin at lunch time.
Here is a running pic.
QDRevenger
#3688
Couple of picsfrom the weekend.
QDRevenger.
#4237
#4238
#4239
gforce replied the topic: Re:My Avenger
Can you tell me where you have the engine mounted? I also have an avenger cat that I cant seem to keep on the water. Its powered with a QD. I have the engine pretty much as far forward as it can go and still the bow is very light. It blows over a lot!!! Can you help?
#6034
ttt
#6109
Dempsey15 replied the topic: Re:My Avenger
I don't have an Avenger, but I do have a conquest. If you already have the motor as far forward as possible, try adding a little negitaive trim in your strut. (tilt the strut where it makes the prop face down) Doesn't take much but it will help keep the bow down. Another one that might help is add a little weight in the sponsons. If you are running pool noodles in the sponsons add some lead egg style weights into the pool noodle. Good luck.
#6116
