My Avenger
QDRevenger replied the topic: Re: My Avenger
Hey Speedn, I made the trim tabs, quite time consuming. I could make you some but they end up quite expensive. Motor is way forwards to try and get the CG further forward in an attempt to keep in on the water at speed. When I repaint for next season I will move the scoop forwards, or maybe just cut the cowl down.
QDRevenger.
#2551
Tahoe1970 replied the topic: Re: My Avenger
Thanks Andrew , But my Sprint has No skeg now ;D Helped a bit on the big end....But suffers a bit in Stability....But who cares @ 74&change.
You can free up a few MPH by ditching the water P/U rudder and using a super thin blade and added a Flushmount or Blast tube for cooling.
Later Wally
#2552
Yeah, I tried chopping off the skeg, made no difference in speed. My strut is high, probably not so much in the water. Good speeds Wally. I just started my Sprintcat. Cant Wait :)
QDRevenger.
#2553
Well , Keep me updated on that Sprint.......They are wicked fast when set/up right ;)
#2554
Speedn replied the topic: Re: My Avenger
QDRevenger
What did you use to fill the seam of the boat? And I am interested in the trim tabs. email me
Thanks
Speedn
#2654
QDRevenger replied the topic: Re:My Avenger
Speedn,
Shot you through an e-mail. Did you get it. If you need any setup specs or tips let me know.
QDRevenger.
#2722
Milner replied the topic: Re:My Avenger
QDAvenger,
I'd love to know the details of your muffler. Your pipe install has inspired me to do something similar on a Conquest using the QD pipe kit, but it appears that your muffler is custom. Care to share the details?
Brent
#2740
Brent,
Custom made but easy enough to make. Post your e-mail and I'll send you a drawing.
QDRevenger.
#2742
That would be great. Any info on how you blended your deck-hull joint would be great too! Thanks.
Brent
#2745
Brent,
Give me a couple of days, just finishing my last night shift. You can edit off your email. I have it.
QDRevenger.
#2748
