Conquest Help needed....
margi created the topic: Conquest Help needed....
I recently bought an Aeromarine Conquest and I can't really figure out where to put the fuel tank..Should I cut the wood from the front of the engine???I saw another guy who had put to the right side of the engine..What do you think I should do>>>???Whoever has conquest photos with his fuel tank setup,please post them in order for me to see..Thank you very much....:)
#4478
marc replied the topic: Re:Conquest Help needed....
Here is a link to the one I built. It may be of assistance. I used a 1000ml bag, but if you want to use a tank, Aeromarine recommend a 16oz flat tank (BT16). Some trimming of the bulkhead may be required.
www.modelgasboats.com/Magazine...e_Conquest.html
#4479
margi replied the topic: Re:Conquest Help needed....
Marc I have read your article and I have found it really helpful..But I have never used a fuel bag and I am afraid that they are more sensitive than the tanks.What I want to know is if it is ok to trim the bulkhead and put there the tank??Would it be better to put on the right of the engine??
#4480
Drinking Gas replied the topic: Re:Conquest Help needed....
Notch it out just enough for the hard tank to slide in it and hold it down .
#4482
Thank you Drinking Gas.Also tell me what do you think about this tank setup that I have found...:) rcmarine.ru/ReviewCONQ7.html
#4484
I would not mount the tank on the side...the cat has enough tendency to dig the inside sponson as it is! Mount the tank upfront is my suggestion. :)
#4485
Ok Marc..That is what I am going to do..;) Thanks..
#4486
NUZUM replied the topic: Re:Conquest Help needed....
put it as close to the front of the starter as possible removing bulkhead in that area wont effect nothing.... cg is at 33% to 34% were i found good for heat setup with mod motor
#4488
Zitch replied the topic: Re:Conquest Help needed....
Hi guys!
this is my building,
the black cat I build for client which love to run along and a huge time.
Usually he runs a gallon of gas mix per day. No any problem with engine fuel feeding.
I place here a new project with new fuel sustem, Orange Electric Conquest cat, for newbie, which runs a short time. I use a 16 oz fuel bag from Hanson. No any cut off of wood needed. 2 nylon band, 1 short line of gas tubing.
Also I place a photo with my Hydro fuel bag. Thanks Marc for good review of yellow Insane!
#4498
#4499
