Prowler build
goesman created the topic: Prowler build
Hello every body.
I have made a super great start on my boat build. This is a first for me and so far i am very happy. Especially since i am wood working stupid, i am more of a metal fabricator. the last two week ends i have been able to get a lot done. The main supports are made out of some scrap quarter inch ply wood from a local cabinet shop. The skin on the hull is from a old door that i had setting around.
Engine will be a Echo GT-200R 21.2cc that i plan on modding some.
#14528
goesman replied the topic: Re: Prowler build
another pic
#14529
As far as i am going to go with the hull for now until i get some motor mounts made and mounted up.
#14530
Little echo engine. So far i have modified the base gasket and put a bit larger carburetor that can actually be adjusted on it. the stock card didn't have any way to adjust it. As the build goes i will get a header and tuned pipe and machine up a header flange. Plus i am going to check the timing numbers and see what kinds of changes can be made there along with some porting.
Some of the hardware i have in mind is the XP-2 drive and rudder from warehouse hobbies, a header, tuned pipe and pipe stop from zippkits. I am going to start off with a prather 275 prop to see how it works out.
Thanks for checking it out, if you have any ideas or suggestions shoot the my way.
Dan
#14531
isuzudude replied the topic: Re: Prowler build
Looks good!!! Keep the posts coming!!!! B)
#14533
dwr9 replied the topic: Re: Prowler build
Looks great so far. Keep up the good work. Lookin forward to more pics as you build. Doug
#14536
Thanks every one, I think my wife is getting jealous, she thinks i spend more time with that boat then i do her some times. :P
#14539
Woodie replied the topic: Re: Prowler build
Hi Goesman.
Just tell your wife, that you love her so much, that you will name the boat after her!
That should do the trick! :laugh:
Ozpulse replied the topic: Re: Prowler build
Welcome to the mad house! :woohoo:
Another prowler build B) I was just saying on another forum that I should carve a custom cowl and make a mold for these boats.
#14541
Redlinemotors replied the topic: Re: Prowler build
The boat looks great, I am starting to see there is a lot of work involved in such a project, as I look over a rigger I have that needs a overhaul for twin motors. Good luck with the build.
Mike www.Redlinemotors.us
#14543
