50" Jersey Skiff first run"Tuning run video added"
isuzudude replied the topic: Re:50" Jersey Skiff first run
Prop choice is definitly an area I'm lost in. I have a couple of 270's to try if I go twin screws, that monster 2 blade I bought, and a couple of 3 blades with different pitches. So it's just going to be hit or miss until I luck across a good combo :S Once I get it built and have some hard dimensions I'll post a pic with hopes of getting some prop help..
#12888
Ozpulse replied the topic: Re:50" Jersey Skiff first run
Honestly Im not much of a prop guru but I put a 270 on the 50cc cat and once tuned even dropped as far as the strut would go it ate it! :blink:
Got advice and now have modded X482! B)
Your probably gonna want 2! :woohoo:
#12889
Thanks Chad... What kind of mod was done? Do I just go online and look for a modded 482? Or do they do different types of mods to them?
#12892
Remove the toungue, round the tips, then cup if needed! ;)
#12893
What's the toungue? And do ya mean round the trailing tips or leading tips?
#12895
toungue is leading tip! MORE TOUNGUE = less rpm/ more bite
then round the trailing tips to about the same as a pencil! ;)
#12896
I just found an excellent article on prop mods!!! rcraceboats.com They explain what each mod will do and how to achieve what you're wanting. Might want to check it out B) B)
#12897
isuzudude replied the topic: Re:50" Jersey Skiff first run""VIDEO ADDED
Trying to get it to come up on the pipe. I think I'm still about 2" too long on my header. It's a lot closer than what it was... just a little more tweakin' B)
Right at the end when it died, found out the carb came loose :angry: Locktite's pretty cheap, live and learn. :dry:
#13051
Ozpulse replied the topic: Re:50" Jersey Skiff first run"Tuning run video added"
Id say its a good thing it didnt get on the pipe! :woohoo:
Can you say 'BLOWOVER' :laugh:
Your gonna need to trim that a bit wetter when you get it there! ;)
Its running better though!
#13054
isuzudude replied the topic: Re:50" Jersey Skiff first run"Tuning run video added"
All I can say is "You go hard or you go home"... I'm gettin' my nerves up for the big showdown with Woodie!!! B) I had a friend of mine tell me that used to race dirt track... YOU DON'T GET TO THE CHECKERED FLAG RIDIN' THE BRAKE" One thing you have to remember... My Jersey is only 50"... The cat without training wheels is 65 1/2" :woohoo: Granted it's going to have 2 27cc's in it... but OH WELL!!!!! :laugh: Chad... Me You and Woodie all think alike when it comes to scratchbuilding ;) It's all wide open... No rules, no plans, no excuses... You build it, tweak it, and put it all on the line B) And if you're lucky, you learn something in the process. But the main priority above all else is... Have a blast and live every day like it's your last!!!! PEACE!!!
#13055
