Scott replied the topic: Re:Wet or Dry?
Just to clear the air on a previous post .... the "Hot Pipe" is nothing more than a sales name for Quick Draws latest steel pipe.
** That said, HEAT within the exhaust system could very well have made the power difference while your o-rings were having the meltdown.
Hotter the gas's within a pipe become, faster the sonic wave activity is. A hotter pipe acts like a shorter pipe and visa versa when cooled down.
Generally the aluminum pipes are slightly milder it there tuning having broad power and run cooler because of the thermal conductivity that aluminum possesses. Steel pipes on the other hand because of there hardness for one, resonate crisper and have slightly better power capabilities. They also run a LOT hotter generally.
So too answer your question, Higher heat within the pipe equals greater BTU's within the engine. It is the expansion of hot gas's that drives the piston down in the first place !
Greater the BTU's at time of combustion, greater the force against the piston, higher the power produced :dance4:
** This is the basic process, and many tuning parameters are at work in the final process. As suggested, try running pipe at a shorter OAL 1/4" at a time and see what it does for your power.
A pipes internal "Back Pressure" also effects it's tune.
Adding or removing a muffler, stingering up or down the outlet size of a pipe are ALL tuning tricks used by advanced tuners.
16 years 10 months ago
#7683
