48" Wildthing set up
Jonh created the topic: 48" Wildthing set up
Hi all
I have a question about the 48" Wildthing....
How do you set it up??
where should I place the engine?
what style of drive should I use?
how lond should the ruader be?
and any other info that can help me finish this projet will be nice THANK YOU
I will post some pic soon for use too see where i am at.
#17918
kennyrach replied the topic: Re: 48" Wildthing set up
HI john their many way to do it . I did one that i building now with Hi all it came down to running this boat with electric motors and I cannot find any place to run it on LI NY only salt water so I go with a Leopard L4074 2200KV 4 pole brushless motor or Castle 2028 780kv any set up will use these battery and ESC
ESC: Castle ICE 200hv up to 12s Lipo
Batts: Flightmax 5s 5800 30c's x 4 for 10s2p.
Electrical horse power is 745.7 watts = 1 horse-power
aluminum adjustable stinger drive for 1/4" shaft (VERSION 2) with teflon bushings inserted. Stinger length adjusted. Ultra strong. Anodized in silver. Suitable fro 45" - 62" and onwards deep v. Specification: see pictureI use the drive for gas or electric set up.i also use this engine mount for gasAnd for the engine i place it 4 1/2: of the forward bullhead and the lower point i can get it and i use a 150mm X 160mm extended rudder it 150mm off back of boat and 160mm down in waterAll my flex cable are 1/4".Here one of my boat i finishing nowalso my post on this site in under kennyrach
#17934
The following user(s) said Thank You: Jonh
dwr9 replied the topic: Re: 48" Wildthing set up
I'll attach a couple pics of the transom of my Prowler, but I'd set up your mono the same. The stinger is from Zippkits. The rudder is an Aeromarine with a homemade standoff. The trim tabs and turnfin are also homemade. Zippkits sells stingers, rudders, trim tabs, and turnfins that are good quality and the price is very reasonable. I would mount your motor as far forward as you can get it, just about right up against the bulkhead at the front of the engine compartment. What engine were you planning to use? Doug
#17936
Jonh replied the topic: Re: 48" Wildthing set up
Thanks kennyrach and dwr9
you have got me pointed in the right dercsion
as for the engine im looking at a 28cc Talon but still looking at any think
here are some pic of my build so far
#17989
Looking good nice wood working.and the weed whacker engine will do fine
#17991
Hi there all,
Thanks for your help but jast a quick one. looking from the back of the boat
in what direction should the prop turn?
Thanks
#18048
isuzudude replied the topic: Re: 48" Wildthing set up
Counter-clockwise.
#18058
Thanks for your help, where I leve there is no one around to help whith any questions or info the thing is I'm a littel lost whith what i need from the engin to the prop?
I'm going to run a 1/4" square sharft and adjustable stringer shaft holder but what elss do I need to make this work right?
or am I going in the rong way?
#18125
RCGasBoat replied the topic: Re: 48" Wildthing set up
Guys is Warehouse Hobbies SPDIII drive, rudder and ISO pad suitable for the mono?
#18638
larryosbourne replied the topic: Re: 48" Wildthing set up
No eBay APP ID défined in Kunena configurationHi looking good bud for what i can see in the pics.I have built 5 of the 48 wildthings and sill at lol.Now doing the weedy thing is OK but this i can tell you that what you are going to spend in setting up a engine in $$$ is not far off a proper engine.time u find this part and that part your going tobe up there in price,What parts ill list is what i found the cheapest and works for me you can take it with a grain of salt or not lol.You can look up my build on this forum under wildthing vs prowler or on (jims rc boat dock )under 48 wildthing.
Ok here cheapest place for your stinger,rudder,,prop,ect (Promise Hobby)Ebay
The engine i use is the sikk 27.4 with the 4 bolt head
www.davesmotors.com/s.nl/c.885...it.A/id.7545/.f
#18647
