My first build on MGB
seanx450 created the topic: My first build on MGB
Hello everyone,
Here are some pics of my Prowler Mono. This is my first mono and my first gas boat. With that being said, I have no idea how high to set up the drive above the keel on a boat this size. 3/8", 1/2", 5/8"? Thanks for looking and any advice will go a long way.
Sean
#17042
marc replied the topic: Re: My first build on MGB
Nice build! :)
I like to make it so the prop centerline can be adjusted somewhere in the 3/8 to 1/2" range and tune it at the lake. I'm sure other guys will chime here too.
#17045
goesman replied the topic: Re: My first build on MGB
Nice job. I have a prowler to that i have built.
Dan
#17046
seanx450 replied the topic: Re: My first build on MGB
Thanks guys for the complements. I glued the deck on this afternoon. I'll be mounting the strut and rudder tonight. Marc I'll follow your suggestions for the stuffing tube.
Thanks
#17047
What you powering it with?
Dan
#17049
Dan,
Im going to power it with a Zenoah G231. From what I hear they make great motors for monos due to higher rpm potential. The motor will remain stock except for a pipe and zero drag seals to run in the stock class we have here in D12.
#17054
dwr9 replied the topic: Re: My first build on MGB
A 231 will work well. I used one for a couple years in mine. I put my stinger 1/4" to the right of center and as low as I could get the stuffing tube. Doug
#17055
Go with this if you can...I was just giving my opinion on how I generally setup monos, but I don't have any hands on experience with the Prowler...Doug has! :)
#17056
whitefish replied the topic: Re: My first build on MGB
Prowler plans question:
Can we take the files for the Prowler plans
to a Kinkos and have them printed full size?
If there is an easier way to make full size
templates, please explain how it is done.
TIA
#17057
Taking them to a print shop is definitely the easiest way to get them printed. Doug
#17061
Time to create page: 0.123 seconds
