"Premium or Regular?"
Ilias_Arkoudaris created the topic: "Premium or Regular?"
I have always had this question,do you think that premium or regular gas is best for our Zenoahs? I am really confused about this matter... ::)
#1574
marc replied the topic: Re: "Premium or Regular?"
Because of the low compression ratio of the Zenoah engines, regular seems to be the way to go.
#1575
Ed Sidders replied the topic: Re: "Premium or Regular?"
REGULAR ---- More of the fuel burns in the cylinder instead of the pipe. The higher the octane the slower the burn. The high octane for me makes the engine and pipe more difficult to tune for a air temperature/humidity/density change. and I really seem to get a little more power from the lower octane. Like loading a pistol cart. for a 2 in. brl. with slow powder, lots of smoke and fire from the muzzle and you can watch the nice slow bullet trajectory. There are lots of different opinions out there. DAMMIT I started another one. Ed
#1576
Scott replied the topic: Re: "Premium or Regular?"
::) Yup ... Low is the way to go ;D
I typically run a 50/50 blend of 86 octane regular and Ozark camp fuel (@ 60 octane)
This blend yealds a low 70 octane fuel that runs REALLY WELL in my Zenoahs.
Scott
#1577
AZGASBTR replied the topic: Re: "Premium or Regular?"
Is this camp fuel readily avaliable? Im sure this question has been asked a million times, but where can you get this camp fuel? Do you have to change your carb settings too?
Thanks,
#1578
Coleman Lantern/stove/heater/etc. Fuel
anyplace that handles sporting goods. WalMart, Cosco, etc.
#1579
seahawkwa replied the topic: Re: \"Premium or Regular?\"
my i ask when you run 50/50 with the colman fuel what fuel ratio are you guys running . ive been using the penrite sin 2stoke oil.... would i still run at 20-1 or lower .
#3649
seahawkwa wrote:
Yea, still mix it 7 or 8 ounces oil per gallon of fuel.
#3651
Piratefish replied the topic: Re:
I have benn using the Honda oil and I was told to use 10 oz per gallon. I am getting a lot of black oil out the pipe. Shhould I cut back to 7 or 8 oz. per gallon? I thought that 10 oz sounded like a lot.
Also do you mean WHITE GAS for camp stoves im gonna give it a try.
Thanks for yur help Scott
#3658
Black Talon replied the topic: Re:
i have been running premium gas just because it's filtered more.
#3721
