Strut bushing longivity??
Rcer created the topic: Strut bushing longivity??
Is thier any particualr brand of strut bushing that seems to last longer?
I have been model boating for many years, Nitro and Gas and it seems these strut bushing just do not last long.
Yes my props are balanced and yes I greese my flexcable and prop shaft every outting. I even drilled a small hole in some of my struts for oiling with a small oiler between runs.
My nitro boats bushings seem to last longer, I think its due to the smaller and lighter props less havoc on the bushings as opposed to the Gassers with the larger heavier props.
Thanks
Rcer.
#7508
ken0276 replied the topic: Re:Strut bushing longivity??
I've been using Aeromarine led teflon bearings with Synthetic grease for many years, they seem to work well for the strut, I would change the bushing for about every 3-4 months.
#7509
marc replied the topic: Re:Strut bushing longivity??
Are you talking about the push-in lead teflons as pictured or the brass sleeve type? I use the brass sleeves and seem to get good longetivity, but then again I don't get in as much run time as a lot of you guys. Only used the lead teflons in a couple boats in the past and they didn't last nearly as long as the brass bushing setups.
#7510
Rcer replied the topic: Re:Strut bushing longivity??
Yeah, I have been running the lead teflons, Octura's, Aeromarine's, and Warehouse Hobbies brand the just dont seem to last.
I do run my boats alot..... usually every weekend and a day or two during the week, so maybe thats all the life I can get out of them!
Maybe I will give the brass sleeves a shot.
I know a few guy's that run needle bearings but those are a PITA too!
Rcer.
#7513
If you are running Aeromarine or Octura struts...try this on one. Punch out the bushings, drill the strut 5/16. Run your stuffing tube through the strut...assuming you use welded cables with collet...(you can splice the stuffing tube with a piece of 11/32 over it if you don't want to replace it completely). Use a 9/32 brass sleeve inside the stuffing tube from the prop end. Easy to modify these struts for brass sleeve setup.
Sleeves are easy to make too: www.modelgasboats.com/Magazine...Strut_Bushings/
I think I show the strut mods in one of my Aeromarine hull reviews...not sure anymore! :)
#7515
marc wrote:Yes, I'm talking about the push in lead teflon one, me too, not much running time, just one or two times a week.
#7516
INEEDSPOTS replied the topic: Re:Strut bushing longivity??
I use the brass sleeve bushings. Have MULTIPLE seasons on the same bushings.
#7533
I just found a used 3/4" length brass sleeve from my tool box, it's for the 1/4" flex cable, does anyone know where to buy it? it looks heavy duty than the led teflon bushing.
#7534
planebasher replied the topic: Re:Strut bushing longivity??
Go to McMaster-Carr's website.
Look under sleeve bearings.
I purchsed the oilite Bronze Bushings: 5/16 O.D. 1/4 I.D. in two different lengths. 1/4" and 1/2". I soaked them in a real viscous oil overnite and installed the longer version in struts.
The dimensions are very tight, right on the money; the Lead Teflon that I removed had a lot of slop in them and I had not run them that much. I have run the heck out of these and there is no slop.
They also carry a steel / teflon version which is similar to the lead teflon; I got a couple of those also but have not tried them.
I also purchased the Teflon tubing for the stuffing tube in 5/16 od and 1/4 id.
Prices are about half of what you would normally pay.
I ordered them before 9:00 am and my doorbell was ringing at 3:00 p.m delivered to my door. Of course that depends on how close you are to one of their warehouses.
#7536
planebasher wrote:Thanks for the website, I found that brass sleeve, 1/4" of ID, 5/16" of OD, 3/4" length and material is bronze.
#7538
