Hydro Setup Tips
marc created the topic: Hydro Setup Tips
** This thread discusses the Content article: Hydro Setup Tips **
#2645
marc replied the topic: Hydro Setup Tips
What are your thoughts on this article? Is it useful to you? :)
#2646
Duane Oldfield replied the topic: Re:Hydro Setup Tips
Mark I think that is great info.As you pointed out these are the most important things to make sure are correct when setting up a hydro. The pics really help.
#2648
wac replied the topic: Re:Hydro Setup Tips
I have a old PI hydro running a mod zen . I run at 1500m above see level and have pushed the boat to 114km/h (71 mph) . The boat is stable with choppy water but when the water is smooth the Right sponson jumps out the water as the throttle is punched , any advice . Have tried pulling the turnfin up towards the back but the speed drops off . The prop is the 7016/2 from prop shop.I can not hold the throttle flat and steer , have to back off because the boat gets air born . Also have a wing but this is set at 0degrees when the boat is flat on the table .
#2658
marc replied the topic: Re:Hydro Setup Tips
1500m = 4920ft elevation. The only way you can get one of these to run those speeds is by having it setup really loose. Here are my suggestions, and keep in mind that chances are you will NOT get 71 mph out of it, but if you want it to handle the way it should, you should shoot more for mid 60s max, especially at your elevation...maybe less.
First, take the wing off...we'll get back to it later.
Adjust your strut for about 1.25" depth setting it up flat on the table as described in the article. Set the turn fin so it is level with the running surface (table) this is a little tricky but you can get it close by setting a long ruler against the inside of the bend, parallel with the bend and adjusting the fin so the ruler is parallel to the table.
Set the steering so the rudder is straight at neutral setting.
Run the boat and adjust the fin and to get the boat to track straight with neutral rudder. Adjust the strut depth to get the boat to run tight without blowing over. This should be done in choppy conditions that closely simulate normal running conditions. Normally when the boat is setup tight enough, it will have a tendency to hop in smooth water, but will hold well in chop.
When you get these settings right, you should be able to take full speed (right hand) turns within a 35 ft radius (70 ft diameter) or so. Don't try to make it hold a 15 ft radius full throttle turn, that just isn't realistic. If it's lifting the RIGHT sponson, you either need to run the strut deeper or raise the back of the turn fin. If you're running a curved fin, raise the back of the fin for more bite. If you're running a straight bent fin, use it only for tracking and tighten the boat with the strut only. Try to keep the strut flat with the running surface (again check on table) at all times.
You boat might be lifting the sponson because you have left rudder input in to keep it straight. This is bad. Fine tune with the strut and fin. The rudder should always be neutral to track straight.
Once you get it all worked out and handling as it should, you can then try it with the wing back on and adjust it until handling returns to where it should be. Those wings can have very ill effects on a sport hydro though, so I would definitely set it up WITHOUT the wing first and take it from there.
Keep us posted. Don't give up. There really isn't much to it, and only through testing will you get it right. Those hydros run real well when you get the setup right. Don't forget, the prop has a LOT to do with the equation also...so a prop with more lift will have similar results to running the strut deeper for example.
Some pictures might help also, so feel free to post a few showing side and rear profiles of the transom hardware and turn fin.
#2660
philippe74 replied the topic: Re:Hydro Setup Tips
Hy Marc
What you are going for a propeller on the Hydro?
I Bulit in the next Time a Seaducer Gas Hydro with Full mod. Zenoah (CC ? )
Gretts from Swiss
Phil
Marc wrote:
#2663
Hi Phil,
You can find all the setup information on the Seaducer hydro in this article:
www.modelgasboats.com/Magazine...ucer_Hydro.html
As for the prop, I recommend a 6719/3 modified by Bob Austin at the Propworks or get the prop directly from Jerry at Seaducer Boats.
* the Seaducer Hydro is VERY sensitive to prop, so get the correct one.
#2665
Hy Marc.
Ok. Thanks
Jerry has a prop on offer. Nr. "SHG1 Hydro or Gas Cat"
What do you think?
Your link is super! Thank you
Greets Phil
#2666
The prop for the hydro is the SGH1. I guaranty you it will work well with that hydro. Not many props will.
#2668
Marc.
Thanks
I now build the hydro and then I look forward.
The engine is a CC or Zenoah from a German tuner. I know he's not.
Phil
#2670
