Hydro Setup Tips
highcomp26 replied the topic: Re:Hydro Setup Tips
What would cause my Seducer to spin out like a 180 sometimes 360 spin depending on my speed. If I am coming down the straights and the boat pulls left and I steer it right it will just spin out. Any ideas whats causing this?:(
#2856
Also it does not steer at full blast at all
#2857
marc replied the topic: Re:Hydro Setup Tips
Honestly, it sounds like a bad, or too weak servo. I had an Insane Hydro doing that to me...my first sport hydro...I quickly found out that you need at least a good 200oz servo, and metal gears. That's what I'd look at first!
#2858
I tested the servo on the table by holding the rudder and there was allot of torque in that servo, do you still think it can be bad???
#2859
Really sounds to me like the rudder isn`t being held sufficiently...could be bad servo, servo too weak, bad/weak linkage...does your servo have at least 200oz of torque? Does the linkage flex?
#2861
no flexing in the linkage and I am running the 200 oz but it has the karbonite gears
#2862
I will swap it out and see what happens
#2863
Also is there any advantages to going with a digital servo than analog?
#2864
Digitals typically have much better standing torque and can have better response, but in all honesty, I run mostly regular quarter scale metal gear servos and have no problems.
#2867
Oldtimer replied the topic: Hydro Setup Tips
After reading your tips on setting up a hydro hull, I am embarrassed at the level of ignorance I approached the subject with 26 years ago. Having never owned a store-bought hydro, I designed and scratch built a shovel-nose hydro with tunnel hull and rear sponsons. While I had fun doing it, I winged the whole thing, and in fact the boat was never finished. I married while getting ready to paint it, and since 1983 it has been in a box. I posted a photo earlier today on a forum thread started by Griz, a guy who apparently lives in San Antonio, Tx. After reading your article, I think I am fortunate I never finished and put it in the water. It would likely be at the bottom of a pond or lake right now. I did enjoy the information..Thanks
#4250
