walbro 257
gzee created the topic: walbro 257
Hey guys I'am new to gas so I have a neewbe question.I bought a 36 in. sprint cat used with a quick draw motor in it this summer.Had a lot of trouble trying to get the carb set on it so I ordered a new wt 257 for it.The proplem is that my old 257 has another hose coming from the bottom of the carb that runs into the motor right beside the carb.Any idea's?
#25194
Bob DeCortin replied the topic: walbro 257
Thats the pulse line
#25196
Canadian Hot Rod RC Boats replied the topic: walbro 257
Swap the plate (with fitting) over from old carb to new - use new gaskets though
257 ? is not listed
quickdrawengines.com/Page_205.html
QD site - call them and ask about using 257? they are great people
USA Calif. 530-938-2485 Monday through Friday 9 to 5, Pacific
#25197
gzee replied the topic: walbro 257
I found a vid of the boat running at Goggle- my buddy 36 areomarine drag sprint cat in testing That's why I bought it . Last time set the carb at home got to the pond made a few adjustments and it quit. Now cannot get any gas to prime when you cover the outlet.Gas line going in is flowing. Had someone rebuild it once. Any other reason beside the carb why no prime?
So found the carb on sale so ordered.If I change the bottom plate will the same style gasket be ok?
QD states that there is another carb that is suppose to be better .-- 33 But for now just try the 257 again
any ideas let me know thanks
#25198
Engines need "3" things to run - compression (ring, seals - gaskets) - spark (plug, pickup, coil - keyway) and fuel (carb, isolator, lines, tank - filter) check and see if you have all the "Big 3"
It may not prime for few reasons
- carb put back together wrong or wrong gaskets
- pulse line plugged or cracked
- fuel line plugged or cracked
- spark good (pickup or coil gone bad)
- bad spark plug
- flywheel spun on key and timing off
- vent (fuel supply ) plugged
- gaskets hard and leaking - carb or engine
- seals leaking
- warped or cracked isolater (carb intake)
- ring stuck or broke
Have to pick one or two - check and try to narrow down
few thoughts
#25199
Hey just checked out your Canadian hot rod site great vids where are you from? I'am from around Windsor On and there aren't that many people that run boats around here.
#25200
Thanks again for your help
Gary
#25201
I'm from Northern BC
Lots guys run down east there - talk (send a pm) to this guy __ Randy Rap - he is from Hamilton and knows who is who in the zoo in Ontario and where guys run
www.modelgasboats.com/my-profi...ofile/randyrap/
Post some pictures of your boat - way easier for us to see if something is wrong - and the guys may recognize the boat from who ever had it last - may have a tip or two for helping u run
#25202
randyrap replied the topic: Re:walbro 257
Hi Gary.
There is a club that run in Tilbury, ON. Great pond and the members would be a great help. Well worth the drive.
Check the www.impba.net website. The club info will be listed under District 2.
IMPBA # 14315 CD
www.nlmbc.org
#25203
gzee replied the topic: Re:walbro 257
Thanks
Gary
#25204
