Stepped Monos
Hugh created the topic: Stepped Monos
I havent seen the latest rules but has there been any amendment to allow the use of stepped monos in mono events or are we still stuck on running them with hydros :unsure: ?
If no how do you go about proposing a change. Do I start on a district level or.....?
Hotshot IMPBA #2077s
#21997
Performance Unlimited replied the topic: Stepped Monos
As far as the rules go stepped monos are not legal and are suppose to be run with hydros. Any rule changes can be voted on at the district level if there is enough interest to incorporate the change, however I do not see any gain in running a stepped mono except for the looks, JMO..
#22001
Hugh replied the topic: Stepped Monos
"Any rule changes can be voted on at the district level if there is enough interest to incorporate the change"
Thanks Les
#22002
"Wetted areas of conventional (left) and stepped monohulls. A stepped mono has less wetted area, and should - in theory - be faster than a conventional monohull. A stepped monohull can be setup to prop-ride, reducing wetted area to the absolute minimum."
By Paul Williams.
Article posted 17th January 2009.
If theres no real advantage wonder why they are illegal only here in the US ? :huh:
#22017
