Aeromarine jersey skiff driver cage
benjimolina created the topic: Aeromarine jersey skiff driver cage
I want to make a driver cage for an aeromarine jersey skiff without welding.
Ideas?
All appreciated.
Thanks.
#20472
Canadian Hot Rod RC Boats replied the topic: Re: Aeromarine jersey skiff driver cage
No eBay APP ID défined in Kunena configurationType in "RC roll cage" on eBay looks like lots of 'cages' from other rc stuff maybe something will work with a little nip and tuck trim job ??
JaT --- Just a Thought ....
Later
#20473
keno replied the topic: Re: Aeromarine jersey skiff driver cage
You could use brass tubing and bend it.
#23091
Ronald Olson replied the topic: Aeromarine jersey skiff driver cage
Styrene plastic rod if you don'r want to weld or solder. Heat it to bend the cage to shape then CA it together.
I've got an Aeromarine JS in the shop and another brand getting laid-up now. I had thought about this also.
#23101
Time to create page: 0.167 seconds
