Dumas Big Swamp Buggy
Nightow1 created the topic: Dumas Big Swamp Buggy
Is there a weed whacker engine out there that would be small enough to the fit Big Swamp Buggy? The reason I ask is I have one still in the box, never had the confidence to build it the directions suck, I'm just plain fed up with nitro, It's expensive, hard to get for me, I live 150 miles from the nearest hobby store that carried anything over 15%, and the engines are a pain to tune. I have fell in love with the ease of gas. Parts, and gas are readily available, and they are a lot easier to tune..
#19082
Canadian Hot Rod RC Boats replied the topic: Re: Dumas Big Swamp Buggy
What is a Swamp Buggy? do u have pictures or a link??
DDM sells lots of air cooled engines for reasonable price
www.davesmotors.com/s.nl/c.885...tegory.27895/.f
link above may help some
#19086
Nightow1 replied the topic: Re: Dumas Big Swamp Buggy
here is a link to the measurements.
#19087
Mercury94 replied the topic: Re: Dumas Big Swamp Buggy
Swamp boats work best with aircraft engines that do not have air ducts and fans on the flywheel to cool them. You could use a trimmer engine engine but you would be loosing alot of power driving a prop and a fan. There are some nice 20cc gasoline aircraft engines out there not sure in that boat they would be too much?
#19090
whitefish replied the topic: Re: Dumas Big Swamp Buggy
Since you already have the kit and want to go gas which in most instances
is a larger engine than nitro, why not just use the kit as a plan set
and upscale them to maybe a 43" - 48" version of the same boat. I
think this size boat would handle any Homey or other gas engine timed
for 8,000 - 10,000 RPM Max (like a gas airplane engine). One of the
tuned pipes like the gas outboards run might fit as well.
Cutting out the pieces with a jigsaw is easy. And no full size, 5 HP,
professional grade saw is needed to do it. I have a 5 HP Craftsman which
I love for full size boat work but it is so heavy my hands get tired quick
when cutting out R/C boat parts. I bought a Harbor Freight #46055 just for
R/C boats (much lighter saw weight) and my hands last a lot longer when
doing numerous small parts.
Several people have built these fan boats and have a blast running them.
Be sure and put a cage on that prop. Having one of those big honkin'
props bite your hand is no fun!
#19096
