26cc Kawasaki, first run.
Ozpulse created the topic: 26cc Kawasaki, first run.
Well all back together after a good clean inside and out(lot of carbon)lost the head gasket, had a play with the ports. Stock muffler box from a blower, only carby I had with no low end needle(WALBRO WA226) using the alloy iso block I made for it.
Waiting now till I can find a decent carby for it, and hopefully a pipe.
#14542
Redlinemotors replied the topic: Re: 26cc Kawasaki, first run.
Looks like you have it running pretty good. Now she needs a hull.
Mike www.redlinemotors.us
#14546
Ozpulse replied the topic: Re: 26cc Kawasaki, first run.
This will be going into the hull I built for my son (A Simple Plan)
Thought the motor will be the closest thing to a stock Zen that I have so should be a good setup to test the hull with. ;)
#14550
Woodie replied the topic: Re: 26cc Kawasaki, first run.
Hi Oz.
That machine sounds really good. It has a nice roar to it! :)
Only thing: I have heard that a motor should never be tested without the exhaust, as this could damage the motor by exceeding the max rpm's.
For my part I would never do that with my precious Blata.
But maybe I am wrong? :blink:
Cheers and good luck! :cheer:
Has the muffler box on it so I doubt it would exceed max rpm.need to hook up my tacho and see what she's doing though.
A tuned pipe will help the motor to rev higher, compared to stock muffler.
What is max RPM anyway? Everyone mods thier motors to get more top end. ;)
#14552
Hi Oz.
To tell the truth, I am not the expert when it comes to motors.
But I guess the absolute max rpm is when the lid blows flaming off the motor. :laugh:
I have been told NEVER to test the Blata at the recommended max 17.400 rpm without the exhaust set on to provide some counter pressure.
So I will not try doing that experiment with a 1.300 $ engine - no way Hosé! :angry: :P
But anyway:
I dont blame you mate! Too nice a motor ya have there! ;)
Somewhere around here I still have a homelite top end we blew off running in a boat.
Too much compression, too many rpms, 2 stroke AVGAS! the same old story.
#14563
Thanks mate.
I'm off to the workshop for now. Have to figure out how to fit the engine rails to the angled bottom and all the spants.
C.U.Later :laugh:
