Primer and Paint for Birch?
isuzudude created the topic: Primer and Paint for Birch?
What's the best primer and paint brand to use on standard Birch plywood? :dry:
#13866
Ozpulse replied the topic: Re: Primer and Paint for Birch?
You not sealing with resin first? :huh:
Cant help you mate as I use polyester resin on all my timber, except the 'Reaper' where I used clear polyurathane all over which took a lot of spray coats as it soaked right into the timber. Was strange like cutting plastic after that! :blink:
#13870
isuzudude replied the topic: Re: Primer and Paint for Birch?
I've already got 2 cans of resins... That was my original plan, just thought I would throw this question out there. :unsure: I even thought of putting some stain on it... might look pretty cool B)
#13872
Woodie replied the topic: Re: Primer and Paint for Birch?
My boatshop recommended me to use the West System Epoxy Resin.
- First rinse off with something de-greasing like acetone. Be very careful: Don't use too much and take special care not to dissolve the glued parts.
- Then mix West System 105 Epoxy Resin with West System 205 Hardener.
- The right mixture can be obtained by using West System 407-2 Syringe Pack.
- Apply with brush or a fine woolen roller.
- If you need a good non-sinking filler to shape up the boat before the above, you can mix West System 410 Microlight with Resin and Hardener. (Follow instructions). It weighs close to nothing. Is incredible strong and can still be sanded into shape.
(Use a mask and rubber gloves - the 410 contains microscopic bubbles - the finest dust I have ever seen).
I have bought this stuff myself. This is NOT my own recommendation - so far, but it should give a "glassy" surface, perfect as a base for further painting of any sort. I hope to get some esperienced MC-painter to do the paintjob.
paulspaint replied the topic: Re: Primer and Paint for Birch?
Hi. You could always do some stain and use clear fiberglass resin that they use on surfboards from tap plastic or other suppliers.for primer and paint use automotive grade epoxy primer or urethane primer house of kolor has a few different primers n epoxys also .I own a body shop I do a lot of custom paint work and boat n jetski repair feel free to ask me any questions if you need sum help....good luck
#14125
Time to create page: 1.383 seconds
