i need a prop?!!!
dpg10 created the topic: i need a prop?!!!
ok i have a 46 inch long wooden v hull and i have a weedy engine that turns about 13,000's RPM's what size, pitch prop do i need?
#12022
Scott replied the topic: Re:i need a prop?!!!
Whats engine displacement ?
Hull type,size and weight ?
#12029
martno1fan replied the topic: Re:i need a prop?!!!
Best props i tried on a weedy powered hull that size was the prather 275 and 280 props.
#12032
dpg10 replied the topic: Re:i need a prop?!!!
its a 25 cc weedy and my boat is made of luwan plywood, it will propabably weight between 10-15 when finished with motor and everything else inside. 46 46 inches long it looks similar to a EASY VEE from zippkits.
#12034
Moofy07 replied the topic: Re:i need a prop?!!!
Hi,
One of my first woodys with a weedy engine used some of the Octura X series props. Started with an Octura x467, to x472. These seemed to be ok, they are not a lifting prop.
Hope this helps.
#12035
well, i also was wondering what style of drive should i use. Its a deep v hull design that i made myself. I know the struts are for the hyrdos and the stinger drives are for the VEE's. Does it really make that big of a difference?
#12038
