carb setting on std rmck
NZG created the topic: carb setting on std rmck
hi i have a standed rmck s254 motor with stock carb and need to no what the needle setting sould be
#11727
Moofy07 replied the topic: Re:carb setting on std rmck
Hi,
I have found lately that the setting to start with is one and a quarter turns on the high speed needle and one and a half turns on the low speed needle. Then depending on the prop used, you can adjust the screws with 1/8th of a turn at a time.
Hope this helps.
#11757
