Homemade adjustable Strut
marc created the topic: Homemade adjustable Strut
I like to mount the strut inside the transom on my Conquests but adjusting the strut is always a real pain. Even with a radio box that it easy to remove, it's still annoying, so I modified this strut to use for this application. The strut adjusts from the top 2 bolts...allows up/down and tilt adjustment, quick and easy. The side bolt locks it in place for extra piece of mind. The side bolt is threaded into the opposing side bracket, so no nuts to hold. Fine adjustments can be made on this strut, similar to a drive unit. I think it will work out nicely. Time will tell. :)
Note: the skeg was welded on as this strut did not have one. Still needs to be cleaned up a little, I know! :)
#10024
Moofy07 replied the topic: RE: Homemade adjustable Strut
Looks good, should work as well as it looks.
Kudos to you.
#10029
Steve Seebold replied the topic: RE: Homemade adjustable Strut
Nice job Marc. Looks real functional.
#10033
martno1fan replied the topic: Re:Homemade adjustable Strut
What happened to the pics Marc ,any chance you can put em back on?.
Mart
#12187
marc replied the topic: Re:Homemade adjustable Strut
I'm trying to dig these back out...
#12210
I really lost these pictures it seems...I will have to take some more with the strut in the boat.
#12211
No probs Marc ;)
#12219
Time to create page: 0.110 seconds
