1/4" REDWOOD STRINGERS
LeRoy created the topic: 1/4" REDWOOD STRINGERS
AT LOWES THERE IS SOME 1/4 IN REDWOOD STRINGERS THAT ARE ALREADY CUT TO ABOUT 4 1/2 IN TALL AND WAS WONDERING IF YOU COULD USE THEM FOR STRINGERS IN A BOAT.....
AFTER THE INSIDES OF THE BOAT IS DONE I PLAN ON COATING FIBERGLASS RESIN INSIDE THE BOAT......
THE MORE I THINK ABOUT IT I PROBABLY SHOULDNT SKIMP ON THE STRINGERS.....
LeRoy
#5759
marc replied the topic: Re:1/4" REDWOOD STRINGERS
You should try to get your hands on some marine grade 1/4" plywood for stringers/transom etc. If it's a rigger, use the same stuff for the sides of the tub. The rest can be done with aircraft grade ply in 1/16, 1/8, 1/32. I don't think you can get these in marine grade.
#5766
dwr9 replied the topic: Re:1/4" REDWOOD STRINGERS
I wouldn't use the redwood, it tends to be rather brittle. Like MARC said, i'd look for some good plywood. Doug
#5833
LeRoy replied the topic: Re:1/4" REDWOOD STRINGERS
YES.......... I HAVE REALIZED THAT I REALLY NEED TO GET A SHEET OF PLY..... FOR 2 REALSON..........
1ST BECASUE ITS 10x STRONGER THAN THE REDWOOD :dash:
2ND BECASUE I HAVE BEEN CONVINCED TO MAKE A RIGGER INSTEAD NOW......(NOW IM FORCED TO):dance4:
HOPEFULLY ILL GET THE PLY THIS WEEKEND AND ILL BE ABLE TO START MAKING THE TUB STENCIL AND ALL THAT FUN STUFF.
:beach:
#5926
