Lynx mono 47"
azli created the topic: Lynx mono 47"
Requires advise on the following setup for my Lynx mono 47 :
1.Engine position - Zenoah 26.
2.Drive system,I'm using M-Boat Rudder & Prop Shaft - Distance between transom and prop.
3.Prop size.
Thank You. ???
#2403
marc replied the topic: Re: Lynx mono 47"
I think the best person to ask would be Dave Marles at Prestwich Models.
Website: www.prestwich.ndirect.co.uk/
#2404
Ian Webster replied the topic: Re: Lynx mono 47"
I can check mine at work tomorrow but here's a start:-
1. Engine position; you will move it around until you get the balance point where you want after everything else is mounted in the hull. If I remember correctly I had a balance point at 34% for a full mod 260.
2. Stuffing tube as low as you can get it and offset 4-6mm to starboard, distance transom - drive dog I can't remember off hand but Dave supplied a Marine Specialties strut. Rudder off set 2.5" to starboard.
3. Props, nothing special here, x470, 7016/2, 7016/3, best I had on my Lynx was a 6717/3.
Here's a few pics, first 2 from when she was built 2005 and the last one from just before she was retired for a Sigma ;D http://www.modelgasboats.com/media/kunena/attachments/legacy/images/3202_setup1_jpg4e0d258eacd069901208a51ac655de53
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/3204_transom_jpg53786d04a248912e5eb9245717175f29
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/3206_new4_JPG1d5524d3baa842166917bdaa52825aa7
#2405
azli replied the topic: Re: Lynx mono 47"
Thank you for the info! :D
#2406
Hi Azli, I have 55mm from the transom to the back of the strut.
The boat is stripped down and I can't check the balance physically but if I read my marks correctly it is balanced at 32%.
Dave did have the setup sheet on his webpage but I see it is now a dead link :(
#2407
Hi Ian,
You mean the CG approx. 32% from transom? Anyway thank you for your good info.
#2408
Yes, CG at 32% from the transom ;D
Good luck and enjoy the boat.
#2409
