hi need help on way to securing this in hull
gixxer6 created the topic: hi need help on way to securing this in hull
#25436
Canadian Hot Rod RC Boats replied the topic: hi need help on way to securing this in hull
There is several ways to mount but the easiest thing to do First is to show us a picture of the boat where you want to mount it..
Just post picture of inside your boat and people here will help you out
#25438
gixxer6 replied the topic: Re:hi need help on way to securing this in hull
hi the boat is an 57" apache with 5" rails in it
#25442
marc replied the topic: Re:hi need help on way to securing this in hull
When I know I can put the box in a boat and it won't be in the way for maintenance (which is easy to do in a big Apache) I like a "no holes" method. Something like 3m 5200 sealant is hard to beat for a permanent installation.
#25444
i was hoping to secure it with screws / bolts for easy removing
#25446
I would Use couple through each side. Maybe 8-32 or 4mm. Use locknuts or blue loctite on so they don't come loose.
Screws tend to vibrate out
I make all miine removable. If there is a gap between box and rails add wood shim to each side of box.
Make sure you don't have pressure on sides from bolts or box may crack.
I sometimes use nylon 8-32 bolts , nuts from Home Depot
#25447
The following user(s) said Thank You: Ronald Olson
Ronald Olson replied the topic: hi need help on way to securing this in hull
I mount mine the same way as Randy does except I use blind nuts tacked into place with a drop of CA glue. Somewhere I got some rubber backed #8 washers to help seal around the hole. They may have come from Micro Fasteners.
Found them. www.microfasteners.com/product...id=17859&page=1
#25500
