Coupler for cluch Bell/How do you use this?
benjimolina created the topic: Coupler for cluch Bell/How do you use this?
No eBay APP ID défined in Kunena configurationSo i have an engine in my boat with this cluch bell www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMZB0
How can i get this coupled to a 1/4 flex shaft being as cheap as possible?
Then i found this
It looks like what i need is it? If not what can i use?
Thank you all in advance.
-Ben
#22684
marc replied the topic: Coupler for cluch Bell/How do you use this?
The clutch bell you have seems to be for Baja cars... I don't know how you could couple that to a flexshaft collet...I would look into changing the clutch bell to one for boats, or replacing the clutch assembly, or getting rid of the clutch all together...
#22686
benjimolina replied the topic: Coupler for cluch Bell/How do you use this?
So what is the part I found? ( please answer) What is the cheapest way to couple my engine to flex cable?
#22694
Ian Webster replied the topic: Coupler for cluch Bell/How do you use this?
Something like this or like this . Whether they will mount to your engine I don't know.
#22695
Hendrick Spoor replied the topic: Coupler for cluch Bell/How do you use this?
Some machining and you're done.
Drill and tap the clutch to 6mm thread. (assuming there's M6 in the belt-collet.)
'Shave' the ring of the belt-collet , so it lies flat on the clutchbell.
Maybe you'll have to drill the belt-collet to take the clutchbell 'stubby'.
20>25mm long M6 setscrew to connect the two.
If you don't need the belt-starter pully , buy a (8mm?) collet for 1/4"flexcable as used on electric-motors.
A flat-spot filed on the clutchbell stubby for the collet set-screws ,
and some grinding of the stubby is all it takes.
Naviga FSR-V NL-13 Driven by CMB-91RS
#22696
Canadian Hot Rod RC Boats replied the topic: Coupler for cluch Bell/How do you use this?
The best way for us to help you is if you
1. Post pictures of your boat and what you have
2. What is boat to be used for ? Sport /Play boat ?
When we see what you have in pictures it's way easier for everyone here to answer your questions
#22697
danielplace1962 replied the topic: Coupler for cluch Bell/How do you use this?
Take the clutch off completely and chuck it in the trash and just bolt a $10 1/4" flex collet right on the end of the crank.
#22742
