What boat to build?
315neil1007 replied the topic: Re: What boat to build?
Hobby Lobby should have it. Or your local HS You'll spend over $60 in wood.
#18347
RCGasBoat replied the topic: Re: What boat to build?
Try Woodcraft. I bought some plywood from them. Not sure if they are maine grade but once you glass or epoxy them over, it should be all good.
#18633
marc replied the topic: What boat to build?
Some Home Depot stores will stock (or can order in) Baltic birch ply which is still fairly inexpensive and will get the job done just fine. It usually comes in 5x5' sheets but I've seen it here at a local home Depot in more manageable 24" wide sheets, both 1/4" and 1/8". Not sure about the 3/16". Baltic birch is commonly used in cabinetry construction.
www.modelgasboats.com
#18641
larryosbourne replied the topic: Re: What boat to build?
Hi home depot store or what ever store you like, all i used is 4x8 sheet of 1/4 and 1/8 it work for 5 of my boats that i have built.
Larry
#18650
Any of you guys have problems not using marine plywood for your hulls?
#18958
Mercury94 replied the topic: Re: What boat to build?
I have no problems using Birch,Maple plywoods. Marine plywoods are resistant to dry rot and not needed in our models unless you plan on mooring it.
#18959
