MHZ Hunter, "The Predator"
FinJohny created the topic: MHZ Hunter, "The Predator"
Hi!
I made a video of MHZ Hunter.
#17800
Canadian Hot Rod RC Boats replied the topic: Re: MHZ Hunter, "The Predator"
Very Nice I seen it on RCU - impressive video and Boat
Post the inside pics u did on RCU ........... very cool
Welcome to MGB :cheer:
#17801
Woodie replied the topic: Re: MHZ Hunter, "The Predator"
My God this video really turns me on!!!
Footage and everything is exceptionally perfect!
And best of all: Engine, sterndrives and servos are JUST the same as I have ready to put into my own 56" wooden mono (still in build).
What a fine run! What a great engine (and the sound it makes)!
How fast and smooth it cuts through the chop with no chinewalking or roostertail!
Speed is not everything. It's also a pleasure to watch a boat with such fine balance.
THATS what I call a boat!
I am UTTERLY AND TOTALLY IN LOVE NOW!
BIG THANKS! This vid will be saved for ever!
Cheers! :cheer: :cheer: :cheer:
Woodie
#17802
FinJohny replied the topic: Re: MHZ Hunter, "The Predator"
Hi!
Thank you so much for the comments!
Here is pictures from the interior and some info:
Engine: Blata 40ccm
Sterndrives: MHZ "Mercruiser" Z-Drive twin
Servos: Hitec HS-5745MG
Top Speed: 70km/h (It is not much, but it is very stable to drive as you can see from the video.
Lenght: 185cm
Width: 47cm
Weight: 20kg
#17816
Thanks for the pics! They are very usefull to me!
Here is what I have in build:
Engine: Blata 40ccm
Gearbox: Same type as yours.
Aluminium engine rails connecting engine and gearbox customized specially for me by Steve Seebold.
Sterndrives: Two ArrowShark. MHZ could not deliver after asking for almost a year. :(
Steering: Two HiTech HS-7954SH in-a-row.
Gas: A smaller HiTech type.
Boat: Deep Vee mono. 2,4 mm birch plywood on strong keel and 12 profiles.
Length: 140 cm. With: 30 cm.
Expected weight (dry) 13 kg. (Power-to-weight ratio: 1:1)! :woohoo:
It's a really tight package, and there's no space inside to give away.
My only real concerne is about stability / chinewalking. :unsure:
I will cross that bridge, when I get that far.
Meantime I hope it's ok if I contact you on and off about practical/technical issues?
Time to create page: 0.280 seconds
