My peells micro 28" v hull
kennyrach created the topic: My peells micro 28" v hull
Hi all .Here a little nice boat i did a year ago .As you see me building my first Peells boat and i have the hull send out to get laser cut.I would cut my own but I fell off roof in 2003 and have 3 main op and two 3" rod and an neurostimulator install .so I can not use power tool anymore .So first let me say Pete know how to build boat and they are 100% super i have build many boat before .but this is the first time i can build a boat with my 7 year old son and we are enjoying it .So hat off to you Pete .Now here what i did already .I lay out all mark on work bench and made a line down middle then i 5min epoxy the 1/8 stringers which was steamed to bend easily .take So here some picture of it
#17163
kennyrach replied the topic: Re: My peells micro 28" v hull
Hi all .Ok here what i did today i sand the hull and put the side on here some picture of today work
#17164
Here picture of the fiberglass beaning done
#17165
Hi all . Here some picture of the motor , drive , prop ,turn fin
#17166
Here my up date picture of my 28" nitro hunter
#17167
Woodie replied the topic: Re: My peells micro 28" v hull
Hi Kenny.
I hate to say this, but your pics are much too small. Could you try to bring the best of them in a bigger size and better resulution?
(Don't ask me how to do. Maybe the mods or others know).
what picture u want want i can pm it to u these picture was taken with phone
#17184
Hi all all here what when into boat.
  • # Full CNC machined Aluminium motor mount made in Fiberglass with a stand Adjustable mount angle .IT Fit 540, 550, 600, 380 size motor and motor with 25mm or 19mm space mounting hole
  • Lehner Basic XL 3600 brushless motor
  • Aluminum adjustable Stinger drive for 3/16" shaft with a Teflon bushing full set version. It comes with brass tube, Teflon lining, flexible cable, prop shaft, prop nut, drive dog and a Teflon washer. Feature: The prop shaft tube is squared which allow no soldering. (Engine collets has to be rounded) Adjustable arms are made of stainless steel for ultimate strength. Anodized in silver
So how all i need it Battery and BEC speed controlle.As you see i made 3 different top for it
#17185
Time to create page: 0.368 seconds
