started on my 48" wildthing
kennyrach created the topic: started on my 48" wildthing
Here my 48" deep v this was make from Doug Reeve plan you can get then onlineThe wood was laser cut from Alex Guzman fromif need item laser cut you Please contact Alex Guzman at:
by email: This email address is being protected from spambots. You need JavaScript enabled to view it.here where i am at now wood was cut and sand the frame done.As you can see Mr Alex Guzman is highest quality top notch laser cutter
#17150
kennyrach replied the topic: Re: started on my 48" wildthing
OK all here where i am at .The frame done and the side are on .Yes i do the side first i do not like doing the 1/8 over hang and filling it in later so i add the bottom then i install wood spray rail .Also u see i have open in bottom of boat radio box this is going to have a cover like the top of radio box just in case i want to change hardware later on .Hope you like so far
#17151
Now i am looking at way to power it ? Nitro or gas Engine and 1/4 " STINGER DRIVE or Rudder Strut Shaft Side Mount
#17152
dwr9 replied the topic: Re: started on my 48" wildthing
Interesting. You're the first person I've seen who has put the sides on before the bottom. If you had the bottom panels laser cut also they may be too small, because they were designed to fit inside the sides, not overlap them on the bottom as you are doing. The sides were designed to extend below the bottom and the resulting vee formed between the sides and the bottom was meant to be filled to form spray rails. Those laser cut parts do look great tho. Wish I had a laser, it would save a lot of time when building. Doug
#17153
HI and thank ,And the laser cut cost me $80 for this boat. I make the bottom 1/8 wider and i use pre formed basswood Triangles for spray rail i been doing boat for 20 year on and off this is my 30th scratch build boat here a pt 109 i did for a friend of mine and some frame from other boat i did for myself http://tinypic.com/a/2nvia/4This picture is when i hand cutter them no more laser cut for me
#17154
marc replied the topic: Re: started on my 48" wildthing
That's a nice build. First time I see that boat laser cut. I have a CNC router here, I was thinking of maybe cutting up a kit with the plans and giving it a shot over the winter if I can find some spare time. Wouldn't be as accurate in the slots as the Lazer, but wouldn't take much by hand to get a nice tight fit. :) Great job, keep us posted as the build goes. I'm liking wood more and more!
#17155
Thank more to come on this build also i am doing all balsa wood one to over the winter
#17157
seanx450 replied the topic: Re: started on my 48" wildthing
Nice job Kenny. I'm building a variation of this hull(The prowler) from DWR9 and I had it laser cut as well. It turned out really nice. Check it out. (My first build on MGB). Good luck with the build. I'll be watching.
Sean
#17192
Wow i thing about this engine but i need to make new boat 8ft here .The engine 6.09 cubic inches or almost 100 cc .info www.conleyprecision.com/609.htm ( boy i am dreaming again )
#17231
Today i sent file to my laser cutting to have the bulkhead top frame made to add to the short bulkhead frame in order to support the top sheeting .I did not like to have the top sheeting hanging into just air
Also I order some HIGH STRENGTH CARBON FIBER FABRIC 12K SPREAD TOW PLAIN WEAVE to do cover boat .I do with Epoxy Resin
#17242
