outside the box made like a box
Rat Bones created the topic: outside the box made like a box
Hey guys
just a bit of an experiment as i brought a box and pan folder for another job so thought i would give this a go
it will probably either go like hell or sink like a stone haha
base is 1.2mm high tensile and top is 0.9mm aluminium inside corners are glued and outside corners will be tigged,hard foam sandwhich,good for a laugh anyway
cheers Mark
#10899
Scott replied the topic: RE: outside the box made like a box
Built like an aluminum fishing boat :smack: .... Frankly if you have all the bits and pieces fitting square and true, TIG welding is just going to make it move around.
Personally would think if you can keep industrial strength adhesive all around you have a better chance of a hull that could work very well indeed if all is aligned correctly.
Pretty dang cool either way ... Nice job !!
#10900
Rat Bones replied the topic: RE: outside the box made like a box
Thanks Scott
i know what you mean about the tig and almost 80% will be glued just the outside of sponsons will be tigged for polish finish and will still have a bit of flex which is what im interested in,just like the way a kart works
dunno if this will be advantage or not but is worth a crack,plus the adhesive dampens down to stop harmonics from vibrations,maybe haha
cheers Mark
#10901
marc replied the topic: RE: outside the box made like a box
I have no idea what to expect as far as performance, could be great, could be terrible...but in any case, the talent you display by putting all this together is very impressive! Cool stuff! Can't wait to see the progress!
#10902
Thanks for the comments Marc
its sometimes just fun to try something completely different and you never know it might just work ok
cheers Mark
#10912
martno1fan replied the topic: RE: outside the box made like a box
Mark thats bloody awesome mate i think you could be onto a winner,good luck mate.
Mart
#10929
Dicko replied the topic: RE: outside the box made like a box
It looks Mean, if it doesn't float, you could always use it as a plug & make a mold from it, then paint it with a ckeckerplate design.
#10936
Rcer replied the topic: RE: outside the box made like a box
One thing thta is for sure........it will handle blow offs without any stress cracks!!!
Actually I think this is a great idea and the hull will be very strong. This method of hull material has proven itself for many years in full scale boats so why not apply to R/C?
Rcer
#10947
Thanks for the positive feedback guys and will keep you posted
#10965
Ozpulse replied the topic: RE: outside the box made like a box
It looks great! Gonna be problem watching it running on the water when its a sunny day though with all the reflection!lol
Big hooks and use it as a RC marlin lure!;)
Break it up with some Satin Black and call it the 'DRONE HYDRO' That would look nasty!
Definately cant wait to see it run!
#10973
