50" Skiff set up?
isuzudude created the topic: 50" Skiff set up?
Ok fellas, got my new skiff in. It has a flat bottom on it so I need to know... Do I need to go with a submerged drive system, and if so, how far below the water line should the centerline of the prop be? And should I go with 30% rule, or should it be a little less? Thanks in advance for any help given. B)
#12643
mitchesx replied the topic: Re:50" Skiff set up?
Hi! Jimmy Geiger gave me some tips on my Aeromarine skiff, I'll see if I cant dig them up for you. I believe the strut should be 1" below the bottom, with a 1 deg neg, motor as close to the front bulkhead (remember -Aeromarine, not sure if yours is an Aeromarine hull), rudder should be level (some skiffs have a slanted transom), tabs slightly above or even with the bottom. A pic of Jimmy's transom is attached, and then a couple of pics of mine...
#12648
Side shot of mine.... Graphics came from Jimmy, Performance Graphix on the Home page - awesome person to deal with, reasonably priced, and will work with you to get what you want!
#12649
Transom shot of mine... I have a J&G in it, but its not completely done yet. Built it to run with my son when he's old enough.
#12650
isuzudude replied the topic: Re:50" Skiff set up?
Not sure of the make myself... looks just like though. Nice lookin' boats. Any information you could come with would be great. With the pics and what you told me, at least I've got a place to start!!!! B) Many Thanks!!!!!
#12654
I'll see if I can find it. I think its on the other computer. Thanks for the compliments!
#12656
I found your manufacturer!!!!!! HiTechMarine... They may have setup instructions for you. Here is their Web site. I cant seem to find my stuff from Jimmy.
www.hitechmarine.org/home
#12773
isuzudude replied the topic: Re: 50" Skiff set up?
Did a few more adjustments....
#16772
Gotta nice run with GoPro Onboard!!!! :woohoo: :woohoo: :woohoo:
#16793
Time to create page: 0.127 seconds
