rev question
petdos created the topic: rev question
Hi to all,just finding out weather this is normal or there is something wrong,motor idles fine, slow acceloration to top speed fine, back off slow no problem,go straight to flat out fine also ,but let go of throttle motor dies,do i need to up the idle trim more or is there acctually something wrong,thanks for any imput.
#9912
marc replied the topic: RE: rev question
When you say it idles fine at first....are you holding throttle for it to idle? Sounds to me like you just need to trim a little bit more idle in your radio. Are you testing on water or on the bench?
#9917
petdos replied the topic: RE: rev question
Hi,idle is set at trim(probably not enough about 1/2 way)and test on both water and bench,thanks
#9924
Set your idel with the radio trim (do not use the idle screw on carb if equipped with one - just remove it) and see if it's ok.
#9925
Thanks heaps,peter.
#9927
