how to mod the g231 pum
visvoet created the topic: how to mod the g231 pum
high there scott. can i use your 260 mods on my 231 or is there other tricks on the 231? thanks. john
#8617
Scott replied the topic: Re:how to mod the g231 pum
For the most part you can, tho some issues of entry angles and port sizes must be watched.
* With the smaller bore diameter, INTAKE port cannot be widened as far.
*Eye brow mod of intake side transfer windows can be a tad larger,
as can the edge of transfer passage near exhaust port.
;) Just watch your port shapes maintaining equal size and flow entry angles.
** Bigger the transfer area gets relative too displacement, slower the outflow of gas's becomes .... so accuracy is paramount !!
Keep Transfer duration stock .... Exhaust @ 178/182 .... Intake @ 156/158
Short pipe of smaller volume and prop down to allow the rpm to get up near 18K ..... Rock the pond :drinks:
Scott
#8619
visvoet replied the topic: Re:how to mod the g231 pum
thanks i will tackle this project with care :laugh:
john :diablo:
#8625
visvoet replied the topic: RE: how to mod the g231 pum
hi scott. do i have to turn down the piston on the 231 aswell
#9648
Scott replied the topic: RE: how to mod the g231 pum
Have run them unturned without issue, But .... do it anyways because it does not hurt anything either.
#9652
