Scott replied the topic: Re: How much is too much?
Andre,
Your GREATEST problem area on exhaust ports and rings is ... the shape of the roof and outside top corners.
The piston ring needs to be first compressed back into it's groove at the outside corners first, then progressively compressing the ring at piston rises in bore with middle/top of port being the tallest area.
If you shape your Exhaust ports roof in this manner, ring clipping will be minimal allowing the largest possible area. (Within reason of course :-\ )
19 years 4 weeks ago
#829
