Hard Chrome plating
David Johnston created the topic: Hard Chrome plating
Im looking for someone who has the capabilities to Hard Chrome plat and finish hone my steel sleeves.... Running in salt water we have to do a lot of after care and im looking to minnimise the amount of rust and wear on my 34mm steel sleeves..
Any suggestions are welcome...:drinks:
#6680
Scott replied the topic: Re:Hard Chrome plating
Simple hard chrome plating is NOT what you want !
What you need to seek is "Electro Fusion" chroming which embeds the chrome into the porosity of the metal.
But that said, if corrosion from the salt environment is damaging the internal bore of the engines, your crank & main bearing are getting destroyed too :dash: Worrying about the bore rusting is something like worrying about your pasture gate being closed, tho the fencing is falling down.
#6682
HMETALH replied the topic: Re:Hard Chrome plating
cheek out a company called U.S.CHROME
#6683
David Johnston replied the topic: Re:Hard Chrome plating
Thanks guys...
I will check out both :drinks: ....
Scott ... I figure I can change the coating on the sleeve, i'll just have to keep check on the cranks and change when needed..
#6708
