Homemade Exhaust?
DirtySnip12 created the topic: Homemade Exhaust?
Does anyone know if you can use copper for exhaust?:?
#6648
Scott replied the topic: Re:Homemade Exhaust?
DirtySnip12 wrote:
Sure .... Tho not a desirable material for the task, it would work IMO.
It will:
Be HEAVY
Run VERY HOT
Resonate poorly because of it being fairly soft.
Will Anneal where really hot and work harden where it flexes.
:ohmy:
#6649
DirtySnip12 replied the topic: Re:Homemade Exhaust?
What would be better?
#6650
DirtySnip12 wrote:
Just like in commercially built pipes .... Sheet mild steel #1 ... Spun Aluminum #2
#6651
How would u make that work exactly?
#6652
Sheet steel is cut too shape and rolled into cones of the desired angles, welded together to get the final shape.
Aluminum either cut from billet or force extruded into the shape desired.
:blush: sounds like you really are lacking in the basic design education on the subject of witch you ask about :(
That's Ok, educate yourself further here: rds.yahoo.com/_ylt=A0oGkjCPgRd...ldandclick.com/
or here: rds.yahoo.com/_ylt=A0oGkjCPgRd...javapipe_en.htm
or here:http://rds.yahoo.com/_ylt=A0oGkjCPgRdKHW8ANi9XNyoA;_ylu=X3oDMTEzNjQ1MzdtBHNlYwNzcgRwb3MDOQRjb2xvA3NrMQR2dGlkA1FSVzJfMTEz/SIG=12bh2q5s4/EXP=1243140879/**http%3a//www.prestwich.ndirect.co.uk/tunedpipetheory2.htm
A simple GOOGLE search on the 2 stroke pipe design will keep you reading for YEARS !~!
#6653
Thanx a lot Scott for the help.
#6674
