7/8 or 1 Inch Header ?
Oliver Douglas created the topic: 7/8 or 1 Inch Header ?
Is there any performace to be gained by going to a 1 inch header and pipe in a mono ?
I am going to try and run my gas SD3 this season:lol:
Thanks for any input.
Olly
Olly
#5205
marc replied the topic: Re:7/8 or 1 Inch Header ?
Theoretically the 7/8" diameter has plenty of surface area to flow the gases exiting the exhaust port. But I think it is more involved than that, as can be seen with the 2-stage pipes... in my opinion on a single stage pipe, the 1-inch header is better than the 7/8" because it is a compromise between a 2-stage pipe and a single stage with smaller header...if that makes any sense. I would like to see a combination of both now that would be interesting!
#5209
CC Racing Engines replied the topic: Re:7/8 or 1 Inch Header ?
All your going to need is just a little patience and a combination of both will appear very shortly.
www.rcbwc.com
Ego Means Nothing
Talent Means Something
Heart Means Everything
Don't believe what you hear
Believe what you see.
Carlo Catalanotto
www.ccracingengines.com
1-504-304-5077
#5210
INEEDSPOTS replied the topic: Re:7/8 or 1 Inch Header ?
CC Racing Engines wrote:
hehehe B)
#5211
Gary Owens replied the topic: Re:7/8 or 1 Inch Header ?
Lo, you just can't keep anything under your hat can you??:laugh: :laugh: :laugh:
#5225
Oliver Douglas replied the topic: Re:7/8 or 1 Inch Header ?
Sooooo..... what are you saying? Stick with my old header or invest in a new one:unsure:
Olly
Olly
#5226
If you change the header you have to change the entire pipe to match. Or were you planning on fitting them? Let me put it this way, if you are running a typical aluminum pipe on 7/8" header and decide to change it for a Powermaster alum pipe on 1" header...yes you will definitely see a difference.
#5228
Gary Owens wrote:
I just said that a little patience is all that is necessary that's all.:laugh: :laugh: :laugh: :laugh:
www.rcbwc.com
Ego Means Nothing
Carlo Catalanotto
1-504-304-5077
#5232
tmoss replied the topic: Re:7/8 or 1 Inch Header ?
Carlo is there a new pipe or not
#5312
