Carb Fuel Inlet Mod
Gumby112087 created the topic: Carb Fuel Inlet Mod
Just wanted to share the fuel inlet Mod that i picked up from Butchtheboatman .
Any time you reposition the fuel inlet on your carb you are asking for an air leak. Simply snap the black plastic off , then use a pair of visegrips to grab ahold of the brass insert then clamp down and twist while pulling the fitting out. Then run a 10/32 tap in the hole to make threads , then dab a little Blue locktite on a water fitting and screw in. This makes for a Leak proof fitting and never a chance of an air leak.
I personally chased my boat in the recovery boat for at least 3 weeks after changing everything trying to figure out why it was stalling every couple of laps.
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/1732_DSC01700_JPG0269165cf833c0bbff539e40beeb4f7b
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/1734_DSC01702_JPG931c8126512402cc808d7ca8d39c3960
http://www.modelgasboats.com/media/kunena/attachments/legacy/images/1736_DSC01701_JPG0af103bd70d1d313cef4756e70453745
#408
Scott replied the topic: Re: Carb Fuel Inlet Mod
Thanks for sharing that, Yup a GREAT mod for sure.
I have many carbs myself with this done.
Too bad we can no longer get the K&B 45 degree fittings :P
#409
Dezracer replied the topic: Re: Carb Fuel Inlet Mod
Can someone repost the pics for this mod ?
Thanks
#6851
Gone On Racing replied the topic: Re: Carb Fuel Inlet Mod
Scott, do you by chance have a pic of the K&B 45 degree fitting..
#7024
Time to create page: 0.108 seconds
