Sikk
2223114 created the topic: Sikk
Bought a second hand SIKK a lot of compression, got gas to plug , got spark , but won't run. Have any ideas? Driving Me crazy down in La.
#4056
Scott replied the topic: Re:Sikk
warped or loose cylinder, damaged cylinder base gasket will cause a MAJOR air leak and loss of case compression preventing start up ?
A sheared flywheel key will place point of spark in the wrong spot even tho you still have spark ?
These will be your most common places to check :S
#4065
2223114 replied the topic: Re:Sikk
THANKS sCOTT, gREAT PLACE TO START. Where can I get a breakdown of a SIKK engine,have any ideas ? I hooked water to the motor to keep it cool if i got it started and noticed some water coming out slowly between the head and block .
#4067
I want to thank everyone who gave me suggestions on what to check out on my SIKK . I pulled the flywheel and the key was messed up, but also the flywheel was bad.Also changed the gaskets on the carb.Waiting on parts now !!!Thanks to everyone!!!
Colen:-}
#4090
Time to create page: 0.195 seconds
