Sikk Piston in a Zenoah?
Zippkits created the topic: Sikk Piston in a Zenoah?
I see that a 34mm Sikk (CY) piston will also fit a Zenoah.
Is there any advantage or disadvantage to using the Sikk in the Zen?
Is it lighter?
For the price, what do you think?
Joe Petro
#3936
CC Racing Engines replied the topic: Re:Sikk Piston in a Zenoah?
Joe,
The only thing I would be skeptical about is quality issues. Some of the CY stuff I have been using just does not have the quality of the Zenoah stuff.
www.rcbwc.com
Ego Means Nothing
Talent Means Something
Heart Means Everything
Don't believe what you hear
Believe what you see.
Carlo Catalanotto
www.ccracingengines.com
1-504-304-5077
#3938
Zippkits replied the topic: Re:Sikk Piston in a Zenoah?
I understand what you are saying for sure Carlo.
I blew the jug off a 27cc pretty easily.
I am curious as to the weight and finish of this though...
Joe Petro
#3940
Scott replied the topic: Re:Sikk Piston in a Zenoah?
Joe,
In stock fit and finish the CY is a lighter casting.
I have also noticed the CY casting seems to be a bit harder material.
While this translates into better wear characteristics, it also translates into piston being more fragile :blink:
In a RACERS world this swap is a BIG No No .... makes engines illegal because of using NON factory parts.
#3941
Roxyflash replied the topic: Re:Sikk Piston in a Zenoah?
I have been using them there great!There real cheap from Daves Motors come with the wrist pin bearing and c clips plus the ring for the same price as a stock zenoah piston.They also are cut on the side for better flow from the transfer port.I use them as im on a tight budget.It dont show the bearing but comes with it!
www.davesmotors.com/store/product694.html
#3944
marc replied the topic: Re:Sikk Piston in a Zenoah?
Sure do like those C clips...they look like they would be much easier to remove and install than the Zenoah ones...as long as they stay put once installed though! :) Personally I am a hardcore Zenoah believer though...I stick with the Zen parts. Good to have input from someone who has tried it! Price sure is good!
#3951
bigspeed replied the topic: Re:Sikk Piston in a Zenoah?
in my experience cy still doesnt have the quality that the zen's do. the pistons are fine in some cases, but sometimes i find myself machining them to fit for better clearance. imo stick with the zen.
#4231
Time to create page: 1.146 seconds
