SIKK coil
Fielies created the topic: SIKK coil
Will the CY SIKK coil fit and work on the ZEN 260.
#3929
Scott replied the topic: Re:SIKK coil
No, the two DO NOT interchange.
The Zenoah uses a 3 magnet flywheel, the CY only 2
The dynamics of where and how magnets generate the current and trigger coils timing point differ between the designs.
:laugh: You can however use either COMPLETE flywheel / Coil set on either engine.
Tho mounting coil of either on the odd engine would take some fabrication.
#3932
