Zenoah stalling coming out of a corner
Captain Hook replied the topic: Re:Zenoah stalling coming out of a corner
I have a stock-as-a-rock hydro (Pro Boat Ms Elam) and have the same problem. I think have everything \"dialed in\", and it dies. I understand too rich too lean etc., but the darn thing dies just as you say. I want to try the prop change, does anyone have suggestions? Type, brand, pitch?
#4046
rocket ron replied the topic: Re:Zenoah stalling coming out of a corner
Yup,I have the same boat only (Formula Hydro). It died 14 times last time out in the same corner. Infact you could place a marker in the turn and it would be almost at the same spot,dead on the water everytime. I've been reading that I should be running a oil/gas mixture of 16:1 instead of (the manual recomended mixture of 32:1). The motor seems to lean out and die,in the turn. The prop is the stock Prather 270,so I'm not sure if it is over proped or not. It sure is a pain,going out to retreve the boat every time in the same area.Ron
#4051
