mod head and terminator carb kits???????
seahawkwa created the topic: mod head and terminator carb kits???????
has enny one perchased one of the mod head kits .
from performance unlimmited .
kit includes mod jug, piston ,ring ,piston pin ,clips ,bearing,base gasget ,
and terminator carb.....
what are these kits like and how good do thay perform.
#3716
rileyboy replied the topic: Re:mod head and terminator carb kits???????
i did, but never had the chance run yet , will run this weekend and let you know
#4034
seahawkwa replied the topic: Re:mod head and terminator carb kits???????
will like to hear what you think of it .let me know what you think of it and how it performs.
hope all goes good for you.
#4037
rileyboy wrote:
hay how did you go with your mod kit......
#4465
HAS ENNY ONE PURCHASED THIS MOTOR OR KIT . AND HAD TRUBBLE GETTING IT TO RUN......
IS THIS SELLER A PROFESSIONAL OR A BACK YARDER ...
I PERCHASED A KIT AND IT DIDENT WORK . SENT IT BACK WITH MY STOCK MOTOR . THAY SENT ME OUT A REPLACMENT MOTOR . BUT THIS MOTOR IS JUST AS SLOW . MY OLD STOCK MOTOR IN THE SAME BOAT ACTULY GOES FASTER THEN THERE CLAMMED FULL MOD MOTOR. THAY EVEN CLAM THAT IT IS RAN ON A DYNO AND PRODUCES OVER 6.42 HP. AND IS A HIGH TOUQE MOTOR . BUT WHEN MOTOR IS RAN IN BOAT IT IS SLOWER THEN STOCK MOTOR AND HAS NO BOTTOM END POWER OR POWER OUT OF HOLE SHOT....
stores.ebay.com/Performance-Unlimited-Products
cgi.ebay.com/Zenoah-FULL-MOD-H...oQQcmdZViewItem
Zenoah FULL MOD High Performance Engine
Previous Picture Stop Play Next Picture
1 of 4
Supersize
Buy It Now price: US $410.00
Ended: Nov-14-08 13:36:29 PST
Shipping:
To Australia -- US $43.90
USPS Priority Mail InternationalTM
Service to Australia
(more services)
Ships to: Worldwide
Item location: ., United States
Quantity: 2 available
History: Purchases
You can also: Email to a friend
Listing and payment details: HideShow
Starting time: Nov-07-08 13:36:29 PST
Payment methods:
PayPal (preferred)
See details
Meet the seller
Seller: performance--unlimited( 560Feedback score is 500 to 999) Member is a PowerSeller
Feedback: 100 % Positive
Member: since Mar-18-01 in United States
See detailed feedback
Ask seller a question
Add to Favorite Sellers
View seller's other items: Store | List
Visit seller's Store:
Member has an eBay StorePerformance Unlimited Products
Contact the seller instantly
Buy safely
1. Check the seller's reputation
Score: 560 | 100% Positive
2. Check how you're protected
Description
Item Specifics - Radio Control Parts & Accessories
Type:
Boat, Watercraft Parts
Brand:
ZENOAH 26PUM
Sub-Type:
Condition:
Fuel Source:
Gas, Nitro
Visit my eBay Store:Performance Unlimited Products
Sign up for Store newsletter
Store Categories
Store home
Engines & Engine Parts
Other Items
FULL MOD
High Performance
Zenoah G26 PUM
'Terminator'
Dynoed @ 6.4+ Horse Power / 2.7 LBS Torque
Corrected 7.74 HP / 3.25 LBS Torque
When used with a steel tuned pipe.
This Motor has only one Dyno Run
This engine is corrected from the Standard 77 degree temp and 0 % humidity
to what is actual at this location: 85+ degrees and Humidity at 65%+
What is Corrected Horsepower?
We have all seen and made claims of an engine’s horsepower. However, this stated horsepower is almost never what the engine actually made for power. How can that be? Most of the stated horsepower numbers are “Corrected” values. The correction standards were developed to discount the observed horsepower readings taken at different locations and weather conditions. It is obvious that an engine builder in Colorado could not produce as much horsepower as a shop at sea level. There is just less oxygen for the engine to burn at the higher altitude. What are less obvious are the other weather condition effects on the engine. So in order to compensate for this all advertised horsepower is “corrected” to several different industry standards where the engine was dynoed.
Don't be fooled by other so called ported cylinders or kits...
Most of them are just a simple stroke with a dremel and a sanding wheel to look different than stock with maybe a slight change in shape of any port that is too conservative to make the ultimate difference!
These engines are dyno proven
and will give you
Awesome Performance!
Race Ported Cylinder..... = More Torque and Horsepower!
Lighten Piston & Ring...... = Higher RPM and Quicker Accelleration!
Crankcase has Improved Main Bearing Oiling....... = Cooler & Longer Bearing Life!
Space-Age Lubricant Applied within Crank Seals that Out Performs Zero-Drag Seals!
This Full Mod engine will give your boat a 'cutting edge' ahead of the pack with ...
Good throttle response
Broad power curve
Smooth idle
Longevity
Fuel & Oil Proof Sealer for Base Gasket = No More blown base gasket.
Transfers Reshaped for More Flow
Intake Reshaped and Enlarged for More Duration and Flow
Exhaust Raised and Reshaped for More Duration , Power and RPM
Larger 13.5mm Venturi Carb for More Power and Torque
Blue Cylinder Water Cap w/ O-Rings
Pull Start Assembly included
Engine comes with Dyno Sheet
Add mounts, collet and Install.
Carb will work with bell-crank or cable
You still use 87 Octane or Regular fuel!!!!
Go to youtube.com and check out the cats and mono using this engine and the TRIK DYNO Run..
Click or Paste the following link:
www.youtube.com/PerformanceUnlmtd
Priority Mail ( USA)
SPRAY THE COMPETITION AWAY !
Visit My Store for other Items.
Official PayPal Seal
Credit or debit card through PayPal
Select a picture
Larger Picture
#4825
marc replied the topic: Re:mod head and terminator carb kits???????
I have never tried their motors, or ever heard of them before this post started. I can tell you right now, the 7.74hp claim has me turning away...I sure would like for them to send me one so I can test and compare it! :laugh:
#4830
marc wrote:
well marc i tryed one and im now on my 2nd motor from them and it is slower then my stock motor. tryed every difrent set up we could still runns like a snail . thay now are telling me that there motor has a higher touqe then standared motor . and works in a diffrent rev range . so when i installed it in my 50 inch cat we trye 7016-2 , 7015-2 and then a 6717-3 blade . and lifted the stut etc . and well this thing whent like a slug still. so all there clames of beeing a great mod motor my be there motor dose run good on a dyno or on a boat thats under 40inch long and as light as a feather . but all ill be using it for is a ash try for my gests to use . as after a day of trying to get the motor to run . the exaust manifol stripped out the 2 bolts from the barrel and well that was it. end of its use realy good mads hay ...i think every onwe should avoid builders that came one thing and deliver somthing elso .
i know when i perchased the original barrel . and had problems . and i stupidly set them the hole motor back . and thay sent me ther so called full mod motor back at no expence . so i thort that was ok . but now to have there hole motor . thats notable to push a boat ennywhere near as fast as a stock motor . and to say it has less touque then a stock motor as its in a diffrent corve range . is just nuts. also when new motor arived the fly wheel keyway was a of set one and was snapped so we had to replace that . now you think that thay would run the motor after its been dynoed just to check that alls ok with it.
well ive now found a great engine builder that ill be dealing with from now on. and i know his motor will be able to push a 50 thundercat or 56inch apache along at a good rate of speed. and not just have dyno charts claming this or vids of boats with ther mods doing great speed.... it realy sucks that this so called profeshanal builders can get away with claming that there motors can do this or that but then once you get the motor it clearly dosent do the job..or thay blame it on that the motor has a difent touqe cerve.
one day marc if i get the time ill email or post some pics of the extreem mods done to the barrel and the intake and exaust ports... to extreem im gessing . and thats probly why thay run ok and rev high on a work bench /""dyno"" but not in real time / in a boat of a desent size. :( :( :( :( and when a stock motor with only a 257 carb can out run it well you/ i realy relize i wasted my monney getting one..haha.....:(
:( :( and i bet ill perobly never hear from them , as thay were verry help full at the start but now dont rely want to know about it ..... just keep blaming the set up . but its stange that every other mod motor ive instaled in mates boat from diffrent engine builders and boats of the same size . go like rockets and perform with out much adjusments at all.....
just gess ive been taken for a ride with this builder ...:angry: :angry: :angry: :angry: :angry: :angry: :angry:
#4842
