ZENOAH engine won't start
mfadlimusa created the topic: ZENOAH engine won't start
I got g260pum zenoah engine and won't start at all after a big crash due to receiver battery. I have tried all the posibilities but the engine still won't start.
What I have done
1. All parts (carb,red coil, black coil and plug ) has been tested and works with another engine
2. Serviced the carb
3. Replace the Plug
4. Raplace Piston Ring
5. Replace Piston
6. try with new gas
the plug was spark and the engine flooded after a few try but the engine still won't start.
PLS HELP ME !!!!!
#3654
marc replied the topic: Re:ZENOAH engine won't start
Have you checked for sheered flywheel key? Ignition timing may be all messed up.
#3661
mfadlimusa replied the topic: Re:ZENOAH engine won't start
Just open the flywheel yesterday and found that my flywheel key has been splited into 2.I will try to make new flywheel key and see how. Will let you know soon. TQ Bro.
#3687
You can get some from CC Racing Engine $1.50 if you can't make one.
www.cc-racingengines.com In the Boats section under Zenoah Engine Parts.
#3692
