To Lean?
Piratefish created the topic: To Lean?
I have a JnG 25.6 with a wyk carb. When I give it full throttle(not under load) it sort of pulsates and spits some gas out the carb.
To Lean? to rich?
#3445
QDRevenger replied the topic: Re:To Lean?
Sounds too rich to me. WYK will spit a bit anyway at low rpm.
Where are your needles. The needle in the barrel I used to run at 7 - 7 1/2 turns and remeber the high, think around 1 1/2 or 2 turns. On a QD so settings should be similar.
QDRevenger.
#3450
Piratefish replied the topic: Re:To Lean?
Hey QD,
Thanks for the tip. The side screw is set at 1 1/2 turns. I cant find my small set of screwdrivers that will fit down the little hole in the top of the carb :( Ill let you know where it is set after testing.
Thanks again
Piratefish
#3459
Problem resolved 7 1/2 turns
Thanks QD
piratefish
#3488
Good stuff ;)
I found my notes and you were bang on with the main needle. 1 1/2 was where I had mine.
QDRevenger.
#3493
