sikk engines
anthony created the topic: sikk engines
Why do they make more stock power? what's different than a standard zen? how popular are they at the races? do they make more modded power? Is a sikk 27cc really a 26.4? are they heavier or taller? ???
#339
lohring replied the topic: Re: sikk engines
The biggest difference I found on an older Sikk was its head clearance was quite a lot less than a stock Zenoah.
#340
Scott replied the topic: Re: sikk engines
Anthony,
The Sikk "marine" engine make more STOCK horse power for quite a few reasons ....
#1 They use a Full circle type crank ... ( better case stuffing )
#2 Pistons skirt, under wrist pin is more open ... ( breaths better )
#3 Exhaust port width and height is more than a stock Zenoah ... ( better top end )
#4 piston to head clearance is a LOT tighter ... ( better torque & fuel burning )
:-\ So stock for stock the Sikk makes more power everywhere in the power band,
But :P uses a 2 bolt cylinder that is a MAJOR weakness.
** Do a tad bit of tweaking on a Zenoah you get to the Sikk power level really easy, take either engine to "FULL MOD" status the Zenoah will run GREAT, the Sikk will fail a lot quicker and be NO where near as reliable ... IMHO.
#341
anthony replied the topic: Re: sikk engines
can you make em 4 bolt?
#342
Nope :P
#343
A little off topic, but we tested the same hybrid cylinder on both a standard PUM crankcase and an RC car crankcase that had been modified to use a standard PUM ignition. Though the RC car crankcase had a full circle crank, there was no difference in power. I know this doesn't seem logical, and Midwest Engines built a similar engine that was very fast, but that is what we found.
#344
what the hell is a fullcircle crank and it's benefits?
#345
The standard Zenoah crankshaft has an offset counterweight like most automotive crankshafts while the RC car crankshaft has two crank disks with a thicker section as the counterweight. This should fill the crankcase more and raise the crankcase compression. I have not actually measured the crankcase volume with a full circle crank, so that could be the explanation for our results.
#346
I,m seeing the new M&D 26cc at 7.0hp still in testing I think it gonna be the way to go or a qd25ht :)
#347
Unless your going to race, don't waste your money on an exotic engine :-\
A modified zenoah set up correctly is more that potent enough IMO
#348
