Zenaoah G260PUM
kriel created the topic: Zenaoah G260PUM
I want to buy a modified Zenaoah G260PUM ...so who and where do i buy from ..any past experience would be appreciated thanks
#3022
Steve Seebold replied the topic: Re:Zenaoah G260PUM
Buy your engine from Ron Buck. His engines run as good as the CC or M+D engines and cost a lot less.
I can't speak for the CC engines, but I have run both M+D and Ron Buck engines and I can't tell the difference.
JMHO
Steve Seebold
#3024
marc replied the topic: Re:Zenaoah G260PUM
Buy from someone that you feel you can trust and will offer you good after sales support. Some of the builders are in it for the long run, building great products and the track record usually speaks for itself. You can also consider modifying your own, following the information on here by Scott Schneider. If $$$ is you primary concern, I think this option is the best.
#3025
kriel replied the topic: Re:Zenaoah G260PUM
Thanks for the fast replys i dont know any(Buy from someone that you feel you can trust and will offer you good after sales support. Some of the builders are in it for the long run)from USA thats why i asked we have 1 supplier here but cant trust him as far as i can throw him (he can do a full mod for about $20).Does Ron Buck have a web site i can look or any other way of contact thanks
#3033
lohring replied the topic: Re:Zenaoah G260PUM
Engine builders:
Ron Buck This email address is being protected from spambots. You need JavaScript enabled to view it.
MnD mddracing.com/
CC Engines www.cc-racingengines.com/
I'm sure there are others, but I've had good experiences with all of the above.
#3047
