Oil Brands - What is Everyone Using?
mitchesx created the topic: Oil Brands - What is Everyone Using?
What kind of oil is everyone using in their fuel? I'm currently running Amsoil, may try Klotz sometime. I saw in RC Boat Modeler that some people were running Mercury Oil (or plugs?). What kind of ratio would you run with something lilke a Mercury Synthetic if indeed you could run it all? This may be an old topic - but I thought I'd put it out there. ???
#2488
Drinking Gas replied the topic: Re: Oil Brands - What is Everyone Using?
I use Cool Power Blue 8 oz to 1 gallon
#2489
marc replied the topic: Re: Oil Brands - What is Everyone Using?
I like to use Honda HP2 at 8oz per gallon. I like a good synthetic oil. You should remember though to break-in your motors with non synthetic oil to get the ring to seat properly.
I know people that run Mercury Quicksilver at the same ratio.
#2490
INEEDSPOTS replied the topic: Re: Oil Brands - What is Everyone Using?
Honda HP2 @ 10oz/gallon
#2491
Captain Hook replied the topic: Re: Oil Brands - What is Everyone Using?
? I'm new to the hobby, in the past I've always been partial to Bel-Ray.
Good idea or bad?
#2492
Scott replied the topic: Re: Oil Brands - What is Everyone Using?
Bey -Ray is good oil ...
Amsoil dominator synthetic at 6 OZ per gallon, thats 20:1 ;D
#2493
Thanks Scott
I always used Bel-Ray in my Bultaco dirt bike and it was the best long before the new copy-cats, I wasn't sure about high temp boat use.
manyhobbies replied the topic: Re: Oil Brands - What is Everyone Using?
For high reving engines it is strongly recommended to use Honda hp2 racing oil. That comes from the makers of J&G engines and Quickdraw engines. J&G says 8-10 ounces per gallon depending on engine rpms. I am no expert on oils and use klotz in my stock zenoah at the recommended ratio, and apparently the hp2 oil is very good stuff for small high performance high reving engines or them guys would recommend something else thats alot less expensive. I don't know what the best is but I will run in my engines what is recommended. The Honda hp2 oil is a little pricey but I have a freind that works at honda and gets it at about cost, 16ounces cost me almost $6.00. RUSS
#2495
Tar18 replied the topic: Re:Oil Brands - What is Everyone Using?
Hi folks
I use Amsoil at 8 oz per gallon
Regards
Tar:P
#2738
CC Racing Engines replied the topic: Re: Oil Brands - What is Everyone Using?
manyhobbies wrote:
The Quickdraw and J&G engines have steel liners that really tend to wear rings out pretty fast. That is why they recommend the Honda HP2 at 10oz per gallon. I would recommend running at least a gallon of fuel through your Zenoah/Sikk/CY/RCMK style engine with a non-synthetic oil at 8oz per gallon before switching to a synthetic oil like Honda HP2. Just my opinion.
www.rcbwc.com
Ego Means Nothing
Talent Means Something
Heart Means Everything
Don't believe what you hear
Believe what you see.
Carlo Catalanotto
www.ccracingengines.com
1-504-304-5077
#2934
