Shortening Spark Plug
seaboyblue created the topic: Shortening Spark Plug
Hello Guys,
I was reading the article on MGB about Shortening a plug. I want to try this for my Gen 2 Insane Cat. Anyone have any idea on the size of the tap/die set that I need to re-thread the rod after cutting?
www.modelgasboats.com/Magazine..._Sparkplug.html
Thanks,
Anthoni
#2346
marc replied the topic: Re: Shortening Spark Plug
M4 or 6-32 should work fine. :) The electrode inside the sparkplug is 3.67mm or 0.145" diameter.
* this info is for a NGK CMR7H
#2347
seaboyblue replied the topic: Re: Shortening Spark Plug
Marc, thank very much.
Anthoni
#2348
Radamus replied the topic: Re: Shortening Spark Plug
I read you have to use a diamond blade to cut the ceramic, is this available as a Dremel wheel? I have the fiber wheels, and they are great but I've never seen a diamond one that I remember.
#2349
Yes the diamond cutting wheel IS required! And yes they are available for the Dremel 1/8" mandrel. They tend to be pretty expensive though. I got a few of them from a local shop here that had them really cheap at one time...
#2350
BMAD01 replied the topic: Re: Shortening Spark Plug
YEP! Marc's right! I've got a mini tabel saw from Harbor Freight. A diamond blade is an accessory for that unit. Thats what I used to cut the porcelan on my plugs. Can't remember the name of the place where I got this setup, but I used a 5-40 die to cut the threads on the electrode first, then followed it with a 4-40 die right over that. The tip of the plug was drilled and tapped 4-40 in a lathe. Brian
#2351
Found it! ;D This is what I used on the electrode. Brian
rodchuck.com/
#2352
